I have a large concrete pier/foundation (2'x3'x5'High) and a large lateral force around 720KN. I have provided stirrups at the top of this pier to take this lateral force, however due to construction realities, I can only get the required stirrups within the top 7-8" of the pier and not the top 5" of the pier that is recommended by various sources and codes. My question is should I be concerned? My thoughts are no. I am not clear where/why this 5" measurement comes from. Because the load is in the long direction of the pier, could you not make the case that the shear load from the anchor bolts would be dispersed downward within the pier concrete and as long as you had the required stirrups within a distance of d from the top of the pier, that load would get pickup by stirrups. I get that you want a decent concentration of the stirrups near the top to help with getting the load from the anchor bolts into the pier but 5" seems very constraining. Thanks for you assistance.
