dik
- Apr 13, 2001
- 26,025
What is the best manner to apply a concrete sealer to an outside SOG so the surface isn't slippery? Should a grit be epoxied on first? Can the surface be roughened first? I suspect the initial finish should have been a medium broomed finish. The surface is a light metal trowelled finish. The sealer will be a silane or siloxane material. Is there a better sealer? With the epoxy the sealer can likely be dispensed with.
Rather than think climate change and the corona virus as science, think of it as the wrath of God. Do you feel any better?
