Trillers
- Feb 14, 2011
- 66
Greetings:
I am designing the structure for a 360’ x 124' warehouse. The structural system consists of pre-cast concrete wall panels and double tees on the roof. The PC DT's are supported by the PC wall panels along the building exterior and by a continuous inverted T beam at the apex ridge line. We will top the roof system with a 4" cement topping with rebar mesh. The cement topping will then be painted over with a double coat of elastomeric reflective paint.
Because we are in a high seismic zone and subject to monsoon rains the owner is concerned about cracks between the DT panels. The architect has suggested a fiber mesh product be laid over all PC roof joints (beneath the rebar mesh)prior to pouring the topping.
I am not sure if this will prevent crackS in the topping. The owner is concerned because this warehouse will be storing wholesale dry goods. Any good recommendations on how to waterproof the DT joints?
