I have two 100% capacity gland seal fans extracting non-condensable gases/steam from the gland steam condenser (for steam turbine's gland seal steam) installed with NRVs downstream of fans. One of the fans showed normal current, its NRV showed no abnormal sound, but the NRV's downstream line remained relatively colder suggesting water/condensate depositing within the line common after both NRV's of these two fans. I want to solve this problem regarding installing a drain valve at common line after NRV, replace NRV with Y-strainer, or simply install a new NRV. Currently I follow the routine of draining the fan bodies periodically. Is there anything I'm missing on?
