Conductive liquid level probe for water. I need some assistance 1
stabmaster
Chemical
Hello. I'm having a controller developed for my process, a solar thermal collection tank (a tank full of hot water).
The liquid level is controlled using a high and a low sensor. I am using conductive probes (no moving parts and relatively inexpensive); however, all commercially available probes are usually either switches or really large gague probes with very expensive junctions.
We mount our temperature sensors at the end of a threadded PVC pipe cut to length and submerged into the tank. We would like to do the same with the conductive level probes. Here is a rough schematic:
the probe might be threadded on the dry side. This side may have terminals, a plug, or wires coming out. The submerged side may have probes, connectors, nobs, or anything that will conduct electricity and is connected to the wire side.
Design considerations:
I would like to find something off the shelf. I don't really care what it is intended for: metal on both sides and some pipe thread in the middle should suffice.
I have decided that AC voltage would prevent electrolysis, so the gague of the metal is not as important as it will not be losing mass.
I need a corrosion resistant metal because it will be suspended in moist air much of the time. Is stainless steel the only reasonable choice?
I am going to use a pull-up resistor for the circuit to detect that the probe is on-line when not submerged. I do not know yet how to figure in the resistance due to the unknown "probe constant" ("k value") of this yet to be discovered probe.
Domestic water may have a resistivity of, say, between 5-500 microsiemens per centimeter.
Probe constants vary from 0.01-50 "per centimeter".
Therefore, the expected conductance ranges from .05-25,000 microsiemens.
In general, the higher conductivity of the fluid, the higher probe constant required. Since domestic water is not considered "highly conductive", I'll consider probe constants from 0.05-1.0, for argument sake.
This translates to a resistance range of 2kOhm -4000kOhm.
On a 24VAC circuit, this translates to 0.006mA to 12mA. Does this make sense? I am rusty on my electrical circuits.
Power requirements would be 0.024 mW to 24 mW.
So the proper pull-up resistor must be on the order of, say 40MOhm? Say, an order of magnitude greater than the greatest resistance expected from the conductive probe.
Will there be a problem with EM interference? Should the pull-up resistor be mounted in the pipe (in the tank), or in the controller? I don't know enough about this to make the call myself. The tank is mostly rubber and foam with very little aluminum on the outside. A copper pipe may be used if EM interference is a problem?
Now this leads to design considerations of the probe. The probe constant may be on the larger end (say near 50) so that the resistance is 2-20kOhm thus decreasing the sensitivity to interference. Is this true? I don't generally have any clue as to the design parameters of a sensor. I'm just using the knowledge i've gained from a course in electrical circuits and no intuition. Please help me gain some intuition on the matter.
The problem you will have with any very high impedance circuit into that tank, will be electrical leakage of the connections through and into the tank.
Humidity will be 100% in there, and there is bound to be plenty of condensation. While touch sensitive capacitive switches work fine, try dipping one into a bucket of water, and see how well it works afterwards.
Not saying the idea won't work, only that it may have some significant long term reliability problems.
A float with some sort of dependable electrical detection is still the cheapest and most reliable. A magnet and reed switch is one way, another is a mercury tilt switch. Cheap, simple and reliable.
Check out pages 12 and 13 of this brochure:
On page 13 is a chart that will give you an idea of resistivity of common fluids.
The advantages of using a packaged relay would be simple sensitivity adjustment in the field and a built-in adjustable time delay for wave compensation.
The level control relay will cost you about $75 for one-off, the probes around $50. A lot less in qty.
