EngStuff
- Jul 1, 2019
- 81
All,
We are in a bit of a situation where we have an existing building with conduits below where we have to design a footing with a decent size loading(see pic below). Even if we try moving the column around, it won’t make a difference since there are conduits all over the ground. Moving the conduits was discussed in depth and that option was determined to be out.
In the sketch below we have a 6” slab above soil that has a k=100 pci, and top of conduits are located about 8" to 12" below the slab (slab slopes). Conduits are extremely close to each other so I cannot penetrate between them.
Only idea I have would be to design a steel beam that is buried and spans about 15’-0”(unconfirmed, have to cut more slab). The ends of the beam would be supported by footings.
Any Ideas or advice?
Note: I did look for similar threads on here, but most were about conduits in the slab. There was one thread almost similar to my situation, but said to move the conduits, but we aren't able to do that on this job.
