hi,
we are analyzing a vertical vessel of diameter 8400mm with height 26000mm, supported by skirt and cone section at bottom,
while checking the junction of cone to cylinder at skirt location, we are doing reinforcement calculation as per ASME Sec VIII div 1 appendix 1-8 for external pressure (Vaccum).
while doing this is it require to consider the weight of liquid filled in vessel while doing reinforcement check for external pressure.
since the hydrostatic head of liquid inside vessel is higher that external pressure (vaccum).
IS it ok to check the reinforcement of vessel under external pressure considering only empty condition?
br
senthilkumar.B
br
senthilkumar.B
