Aakalim103
- Jan 26, 2019
- 26
We have a narrow concrete slab supported on three sides on a WQ steel beam (Box beam). The slab is part of a hollow core floor system and on the fourth side, it is connected to the hollow core slab. I have attached a sketch to explain the situation. On the longer side, the slab is only resting on the flange of the WQ beam and is not connected to it in any other way. On the other side, it is just connected to the hollow core slab through holes which will be filled with concrete and rebar ties going from the cast in place concrete to the hollow core.
I am confused as to what support condition i should take to design this slab/beam. I am inclined to design it as a beam simply supported on the shorter edges as shown in the sketch. However one of my team mate thinks that it should be designed as a slab simply supported on all four sides. My rational for designing it as a beam is that the connection to the hollow core is usually provided only to cater for the horizontal shear between the hollow core and slab or wall, so i don't think it will work for the vertical shear, unless it is designed as such. Right now we just have two 12mm diameter rebar loop in for each hole as shown in the sketch. On the other longer edge it is just resting on the steel beam without any shear connectors or embedded bolts, which means that in case the steel beam deflects more than the concrete slab, the slab will not be supported.
I would appreciate your opinion on this.
Thank you.
Thank you.
