zjr5273
- Jun 2, 2021
- 8
I am researching a means of connecting a cantilever steel beam to the vertical face of a proposed concrete column. The attachment of the steel beam to the concrete column will occur at a much later date. I am avoiding threaded anchor rods as the projection of the threaded rod from the face of the concrete column is undesirable. I am also avoiding post installed anchors for the risk of damaging the column reinforcement in addition to lower allowable strengths compared to cast anchor rods. I was hoping to locate the invert to a threaded anchor rod with a threaded coupler of sorts that attaches to the formwork and casts into the concrete leaving a threaded plug for which to install bolts into. Has anyone come across or used something like this before?
Thanks,
rzoppa
Thanks,
rzoppa
