Connecting line to surface bodies in design modeler
Hurricanes
AU
I have a simple cylindrical column which I have modeled as a surface body. Protruding normal out of this column I have a line body which represents a beam. I can't for the life of me work out how to join the two bodies so they will be reconised as connected when the model is meshed up. 'Joint' doesn't work for me and I have tried pretty much everything else I can think of. Help please!
I think you will need some APDL code to define line to surface or point to surface contact between beam an cylinder.
Alex
MESHPARTS
Tuning Your Simulation
It's a bit tricky but possible in DesignModeler. Which version of ANSYS are you using ??
Can you attach here the model you made so far?
Best Regards,
Bob
