I have a 24" line that I am running under a creek. under the creek, i am required to use DI. I want to tie in to a 24" line that is 949_PVC on the other side of the creekbed.
TCEQ (Texas Commission on Environmental Quality) madates that a manhole be used when changing direction or moving laterally...but doesnt say you must use one if changing materials. I am wondering if I need to put a manhole there, or can i just put a fitting there to make it work and be ok?
TIA, Chris
TIA, Chris
