taylors1243
- Dec 17, 2008
- 1
I am having alot of failures on Onan engines Model# DN2M-1 engines. I have been unable to get a drawing of the connecting rod bearings (onan part number 186-6081).
I basically need to find out if the upper half bearing has an oil hole and grove in it. The ones I have are flat on both sides and that doesn’t make a lot of sense to me. I have wear showing at less than 40 hours with little or no load and catastrophic engine failure at 70 hours or before with them loaded. I have been unable to tear apart a fully failed engine but I did tear one apart that is vibrating like crazy - and that is what I found - no oil hole or groove in the connecting rod big end bearing.
Can anyone shed some light on this for me - please!
Thanks!
Thanks!
