enginesrus
When looking at the front or rear of a normal automotive or industrial piston engine, that is the vibration damper end or the flywheel end. In your opinion what sides of the rod see the most loading or stress, the right and left sides or the front and rear? Just curious of responses not asking things I don't know or understand. And if you want to get real involved use normal CCW as viewed at the flywheel end.
