ruzfactor
- Oct 27, 2007
- 8
Hello all,
I am having some issues with the moment and forces at hinge connector. I am running a dynamic implicit analysis, and extracting time history output of CTF and CTM. CTM along axial direction is zero which makes sense. But I am trying to understand how abaqus calculates the moment in hinge connectors. Is this based on global coordinate or local nodal coordinate?
I have used two wire elements to create a hinge connection.
Node-1--------Node-2--------Node-3
Element-1: Node 1 & 2
Element-2: Node 2 & 3
I assume the moments (along other two directions )in the two elements should be similar. But I am getting significant differences. That's why if anyone could suggest how CTM and CTFs are calculated for the two elements connected to create a hinge, would be helpful to understand. Thanks in advance.
