Guys,
I am new to Hypermesh and bit (actually a lot) confused with welding and bolting connections. Can anyone help me out regarding the below questions..
(1) I have to connect two components with M5 fasteners. I have mid-surfaced, meshed the surfaces and created the spider for holes. Now I have to select the centre nodes of both the holes with a bar/rod/beam element. Here is my confusion. What I have to select here? Where to give the dia of the 1D element. Do I have to give the properties for the new 1D element as well.
(2) Same problem and if I have to do spot weld instead of bolted joints (assuming no holes there), which option I have to select and where to give the dia of the spot weld for example 7mm dia.
Thank you very much in advance.
