Spartacus89
Hello Engineers,
I was wondering if anyone knows what consolidation is required to tend a clay from undrained to drained?
If I am doing any design (retaining walls, quays etc.) I would always check both conditions and I don't know if there is a way to not check both.
Books such as Craigs state that when dissipation is completed that the soil is considered drained. However, if I for example: -
1) create a bund which increased the total stress and the pore water pressure by 50kPa, then from odometer tests that will create a settlement of 100mm in 2.2 years
2) create a bund which increased the total stress and the pore water pressure by 200kPa, then from oedometer tests that will create a settlement of 142mm in 1.7 years
In both of these examples dissipation has occurred, otherwise the soil would not consolidate, but neither do I believe that they have tended from undrained to drained.
If anyone can give me some guidance, even if it's that I need to check both cases and let the Professors worry aboutwhat is required for it to change.
Cheers
D
Cheers
D
