the only problem with the search function is that the workbench criteria doesn't work.
Does anyone know a way to select only the assembly constraints thrue all assy levels in one deal. the contextual menu method is quite time cunsuming on a large assembly
Yep, the constraint filter function is the best for you. forget about the search its a little to long and complex.
Can't find it ? Do this : Under the View menu (Yes the one on top between Edit and Insert) So, View + Commands list + ConstraintFilter. You'll have a little window to hide all constraint or more...
There's no icon for this function, create one (that's what I did) using Tools+Customize+Commands.
Take Care, cause this will hide ALL constraint sketcher constraint, Assy const... So don't forget about this function if you are in sketcher mode and couldn't see your dimensions.
