How are construction joints handled in a 2-way PT slab construction? If the tendon is continuous through the joint, it seems like the moment capacity of the slab is the same as if the joint weren't there, correct? Why would you use a intermediate stressing anchor vs, not one, but still having the tendon go through? Is the only consideration to provide some mild steel to take the shear forces??
