Hello COLLEAGUES, this is my first post on forum.
I did a simple study for practice the code AISC LRFD 99 on SAP2000, and I found a problem with the iteration ratio demand/capacity calculated by the module Steel Frame Design. The conditions, loads and sections are well indicated. Also I checked with other codes ASD89, and result was well. Add the file about the result
there we see that:
phi*Pnt=11181 kgf (daN)
Pu=1600 kgf (daN)
then by the code the ratio is Pu/(phi*Pnt) ; 1600/11181=0.143
but the program show a ratio of 0.072 (a half, of side of Insecurity)
here is for see the load
thanks for your time, I will wait for your answer.
Wilson
there we see that:
Pu=1600 kgf (daN)
Wilson
