Dear All,
While doing the contact analysis(Using Ansys), the common problems i am facing are with the convergence of the model.
i) I regularly use point to point contact elements and try to converge the problem(Number of elemnts in my model usually be around 200000), but most of the time i am failing to converge the model. Then i use weak springs with very low stiffness. What i couldn't understood is that a finite number of weak springs with a very low stiffness of "1" will converge the model.Can any one suggest me on this and some tips for getting the model converged.
ii) Will the mesh pattern aroung the contact region will cause a great concern in convergence ?
Thanks and Regards,
Krishna
Thanks and Regards,
Krishna
