Hi
I need to measure the temperature between 2 ceramic plates (30mm wide, 500mm long) which are in contact. A heat source will pass from one end of the plates to the other and the power to the heat source will be modulated via the temperature measurement device. A pyrometer could be used if we were to use glass as our upper plate. However since the ceramic is not transparent the pyrometer is not an option. The max temperature will be approx 450C.
So what I’m looking for is a thin continuous temperature sensor. Any suggestions greatly appreciated.
