continuity testing
tamethetikbalang
4
Hello everyone,
I'm trying to measure the circuit protection diode of a certain pin, the problem is I have a bypass capacitor connected. Unfortunately, there is no way to disconnect that cap. I can measure ~0.5V, but I need a high settling time prior measurement. Is there a way to speed up my testing? Thanks in advance.
Just to add, I'm forcing 10uA from ATE and measuring it using its voltmeter (FIMV).
Is that truly a constant 10uA current or is it a constant voltage with a maximum of 10uA? If it's constant current, the voltage across the cap will be proportional to the current. If it's constant voltage, then it'll follow a e^(t/RC) curve. Either way, if you can increase the current, the capacitor voltage will change faster. Just don't exceed the voltage or current limits that the pin can handle.
Glenn
Why is there a bypass capacitor on a pin where you need to do this test? Conversely, why do this test if you have a large capacitor attached to it? Is this a signal pin? Or an unused pin?
TTFN
FAQ731-376
@geekEE - the 10uA current is the widely used value when checking the circuit protection diode. My last resort is to increase that value, same as your idea. Unfortunately, I don't have the specs for the diode, maybe 1mA would do. What do you think?
@IRstuff - this is an input pin. Maybe the one who designed the DIB did not foresee this would happen. He could have put a relay to connect/disconnect the cap, depending on the tests. By the way, this cap is recommended by the device datasheet.
Is this forward or reverse? Forward is a no-brainer, since the power dissipated, even at 1 mA is trivial.
Reverse may, or may not, be OK. Typical reverse breakdown is around 30V, so there's be about 30 mW of power, which is not a big deal. However, avalanche breakdown can induce hot electron effects that tend to trap electrons in the field oxide, thereby reducing the breakdown voltage in the region.
TTFN
FAQ731-376
It has to be forward bias. I guess I have no other choice but to increase the current to minimize the settling time.
