GreenJug
- May 7, 2023
- 8
Hello. I was curious about the support reactions of a continuous beam with 4 spans. The end reactions are pins but the middle three reactions are springs (i.e. they aren't pinned, they are simply bearing over a surface). Does the fact that these supports are springs affect the reactions? Please have a look at the illustration below. How would the reactions in a continuous span beam change with the three reactions in the middle as springs rather than pins?
Any help is greatly appreciated! Thank you.
