Hello All,
I am looking for a bit of confirmation on my process to make sure I am not missing anything (Please refer to attached detail). I am looking to reduce a continuous weld to a stitch weld to prevent warping during fabrication. Currently plate "PA" is welded with a continuous 1/2" fillet weld top and bottom for the full length of the plate. I would like to reduce it to the weld shown in the detail (1/2" fillet @ 3-8 w/ 4" cont. ea/end). The loads shown I have factored and are quite conservative. My process amounts to:
Calculating the required weld size and length based on AISC 14th Table 8-5 (Angle of 30 Degrees)
- D = 1/16
- L = 5.1"
Taking a ratio of these to what is originally specified
- (1/16) /(1/2) = 0.117
- 5.1"/43.5" = 0.117
This would mean I only need 11.7% of a continuous weld, but to be conservative would like to keep 37% of what I had (~ 3 x 11.7%) so 1/2" fillet 3-8 is what I decided on.
Is there anything I am missing or not considering here? I did not design the original weld so it threw me off to see how little I actually needed which made me question my work.
This is not a normal design for me so any confirmation that I am on the right track would be great. Thanks for the help!
Matt
- D = 1/16
- L = 5.1"
Matt
