pappy64
Computer
- Jul 11, 2012
- 7
I would like to place control joints along walls so they can be hidden and fit well with ceramic tile joints over them. However,I am concerned whether such control joints would activate because beneath walls of the slab is thick concrete foundation. The below image is a side view cross section of the slab showing the proposed 4 color coded cement truck pours. The 2 construction joints through the slab on either end of the green double as control joints. The plan is the slab is 4" thick, the 2 joints are grooved 1" deep, and no slab rebar will cross the joints though rebar deeper in the foundation will.
