Control line weight?
Ralph2
Industrial
May 3, 2002
345
Is it possible to control the line weight of an annotation, to be the same value as that use in dimensions? (SW 2012)
Thank you for your time.
Try using the Line Format Toolbar. That was what it was for or so they say.
Thanks Chris and quest4k.
I finally had some time to check your suggestions and could not find anything that worked. Every place I looked the specs for both the dimensions and annotations are the same. This whole problem.. insignificant as it is.. brought up another issue that I will inquire about in a new thread.
But.. it seems different printers handle line weights differently. Printing from SW to my home printer preserves all the line weights as it should. However if I Print To PDF the line weights are ignored and all come out equal. I suspect this is due to "my" pdf printer (CuteWriter) and I wonder if other SW users have alternative "Print To PDF" solutions that work better.
We use PDF file allot, bot for the floor prints and the sales prints and have no problem showing different line weights. We do a save as PDF file to each of our parts drawings and from each of those PDF files we send then to printers all over our network and to the website. Just be careful to check all of the PDF settings. Well all I can say,is it works fairly well for us. Maybe look at eDrawings as well. Good luck.
Ralph2,
I'd suggest trying out Layers which have a line thickness setting. Since the Annotation is not a curve the line format toolbar cannot help you unless it's sketch text.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
Thanks Micheal.
I will play with it some more.. have never tried / used "layers" except in AutoCad. As I could not preserve any line weights before it only mattered while the drawing was on my monitor. Now, thanks to the forum's help "print to PDF" is making my line weights show so I should try again.
