Justice100
Chemical
- Jun 18, 2008
- 51
Hi there,
A problem I've come across a few times and had a few different opinions so I thought I would asked here...
Typical rule of thumb for allowable control valve pressure drop is 30% of the total frictional losses or a minimum of 0.7 bar. How critical is the minimum value... I have a system with quite a low total pressure drop so I can achieve the 30% criteria (using the typical line sizing velocity/DP criteria) but not the 0.7 bar. Is the minimum of 0.7 bar critical? In this case I have a flashing liquid (1 barg) upstream going to a tank at 0.1 barg using a 200m line with a 10m drop. It will be used very infrequently so trying to minimise investment without having to rely on an operator to control it locally by hand.
