Finglas
- Jan 24, 2009
- 137
One of our service engineers wants to know if it is possible to bring one of our machines which we are still building on our own premises to a controlled stop but which doesn't actually dump the air in the system. Technically, in this scenario there should be no possibility of movement of pneumatic cylinders as the air already in the system will maintain them in their current position. What I want to know is does this contravene any EN standards?
Typically, when we bring machines to a controlled stop and then open the doors of an enclosure (usually a 3 to 5 second continuous holding down of the same stop button) to get inside a machine, the air will be dumped on opening the doors. In the above machine, vertically oriented cylinders have check valves to stop them dropping and risk assessment has been done already to make sure parts which are held (suction cups, mechanical grippers etc) are safe/unsafe to be dropped.
