wingguy14
Automotive
- Sep 16, 2010
- 7
Hi All,
I am new here, and am looking for some help with a new project, that goes into the realm of simple electrical engineering, which is outside of my comfort zone. I have spent quite a while trying to figure out a solution, but I can’t come up with any sort of elegant solution… I am hoping I can find some help here, or someone who is willing to take one a very small side job and design this for me, I can offer a fee.
Project Overview: Automotive race application, need to control a pair of linear actuators based on either a rotary dial or accelerometer outputs.
Part 1
I need to be able to move a linear actuator to 5-7 different remembered positions. The linear actuator I am using has a built in potentiometer. I want these 5-7 positions to be controlled via a multi-position rotary switch. This would all be off of a car’s 12V system. I have been told that this is pretty simple micro controller work, but again its outside of my scope of knowledge.
Part 2
I also would like to have the ability to have 3 of these positions to be selected via outputs from a 2 axis accelerometer. Position 1: This would be the default position (Less than .5G from either axis). Position 2: Needs to be selected when the Y axis sees >.5G(car is braking) Position 3: Needs to be selected when the x axis sees >.5G(car is turning), this needs to override position 2 if both axis are experiencing G loads. It would also be good to have some ability to adjust the G thresholds.
That’s really the quickest overview I can give. I have found an off the shelf actuator control that can remember 3 positions, and I was going to use that, but I keep getting hung up on what type of switch you used that is activated at a certain voltage output from the accelerometer. So, at this point I am really looking for a custom solution as opposed to cobbling together off the shelf parts. Thank you ahead of time to anyone who may be able to provide some ideas, or to anyone who would want to design this for me. Its much appreciated!
Part 1
Part 2
