jamesbanda
Chemical
We have located an installed valve (following a relief valve) audit which exceeds 10% for the outlet losses.
Are there some guidlines on what would be an acceptable limit above 10% limit outlet losses for a conventional valve. I understand if this was a new installation we MUST correct this and use ballanced bellows. but this is an older plant, which the orginal cal using an old method was just under 10% but using a more modern method now exceeds 10%. We found this updating the calcs to API521 so we considered all credible over pressure cases not just fire as was done previously (a long time ago)..
