FrankMalone
- Jun 20, 2003
- 76
I'm using NX Nastran and SOL106. I have made a non linear analysis, and I have problems with the convergence of the solution.
In the convergence criteria menu there are three possibilities, displacement, load and work, by default load and work are checked by the software.
If I check displacement and work and uncheck load, the solution converge. But if I try the default load and work the solution does not converge.
Could be the solution accurate enough? What is the difference between the convergence options? Which must I choose?
Frank.
Frank.
