convert a slip ring motor into a variable voltage transformer? 4
ankervik
41
Someone told me it is possible to convert a slip ring motor into a variable voltage transformer? If so what would be the set-up? We often have problems running up larger AC induction motors unloaded (380v/50Hz). Our present test bench doesn't cope too well when running motors over 250kw
Rosenborg supporter even after Brann won the series hands down? Spent a little time in your neck of the woods way back late 80s. Had a base in Linköping a short while, also did some product training in Västerås...Jätte bra!
Small world huh!
