atheeanne
New member
- Sep 21, 2006
- 6
I am a plasma physics innovator. I just completed the design of a power generator using plasma-MHD. The system outputs square waves at approximately 3000 Hz with powers output between 2.5 MW (500 Hz) to 20 MW (3 kHz). Does anybody know how I can convert this to useable utility power frequency (50/60 Hz)? I can do this by slowing down the system, but I am loosing too much power. Also, I am extracting power through multi pin electrodes at maximum 60 Amps per pin, so each pin can create its own circuit (at high frequency the pin current is under 1 amp). Is there a simple method to digitally change the shape from the square wave output to a sin wave to match the shape and frequency of the local utility power lines?
