Convert entities - can't select all contours
Simon205
151
If you have a face with several open & closed contours, then create a sketch on it, select the face then click 'convert entities', why does SW only convert the the open contour(s), and not the closed ones?
Any ideas?
Cheers,
Simon
SW2009 SP4.0
Yes, SolidWorks does convert outer most loop when you covert by clicking on a face but....
There is another way, not exactly what you want or may be........
select the face & also select one of the edges you want to convert(from inner or closed loop).......then click convert.......this way you can select which contour you want to convert from a given face.......
Hope this helps....
Gurjeet Singh
Pick the face and then the edge of an interior contour and you will get that interior contour to convert.
