fighterpilot
Military
I have an assembly in UGNX5. I convert that to STEP214 using UG's converter and then I use the batch converter in V5R18 to convert to CATPart/CATProduct. In my final CATProduct however, I get multiple instances of the same part. For example, if in UG I had a plate with 4 fasteners, after conversion to V5 I have a CATProduct with 2 plates on top of each other and 8 fasteners, 4 sitting on top of the other four at the same locations.
I can't figure out why I'm getting 2 components when I do the translation. I have the same issue if I just call up the step file into V5 directly.
Any ideas?
Thanks...
Fighter Pilot
Manufacturing Engineer
Any ideas?
Thanks...
Fighter Pilot
