gcrow
Automotive
- May 23, 2013
- 25
We have to upload our asm files into our OEM teamcenter. We have been getting away with putting our asm files in as bulk parasolid files. The oem now wants us to supply individual part files because when they open the file all the see is "body" in the part navigator. I have been going through this site trying to find a journal or work around with no luck. What i need is a way that i can get a single file with with parasolids that show the component name, has material associated with it. I know you can do this manually but there is no association and will have to be done every time we put somehting in teamcenter. We have attributes in the file sucha as DB_PART_NAME and P_MAT that i would like to be added to the solids. Ive tried wave and that only shows as linked body and doesn't have the part name or material. Catia has a function called generate CATPART from PRODUCT that that converts an asm file into a single part file and names the bodys the file names. This is what i need in UG.
