HBtheElectrician
- Sep 29, 2013
- 2
- 0
- 0
I have a 240volt 60HZ motor, I believe it is a 5 horse, however the name plate states it is "Special" and is continuous duty . The motor goes on an air compressor that is in Togo Africa. When I received it the start capacitor was blown and it appeared that the start windings had gotten warm. The power in Togo is 230volt 50hertz. It is my understanding that to keep the motor from overheating one would have to bring the voltage down to 80percent of the nameplate, so this was my first thought. I have not ever dealt with power in other countries and I am not how it is used. I was looking into voltage converters, but when it started to talk about converting from 110/120 to 230/240 I got a bit confused. Here in the US when you are speaking of 240 single phase you are speaking of 2 hot wires. So, when you are speaking of 230 in Togo Africa are you still speaking of 2 wire single phase?
