Gymmeh
- Aug 30, 2007
- 1,059
Since the economy is tight.... i have been assigned to squeeze every penny out of our conveyor design...
I have been spent the last 3 weeks working on the discharge, safety guards, etc. I have also seen that others companies use much less structure then our design.
Actual issue:
We have formed sheet metal side walls which a) keep material from falling out b) protect the nip points on the load idlers. From what I gather the side walls are not considered in the structural design. I have tried the machinist handbook and my old collage books for calculating the structure of bent sheet metal, but did not produce anything i have confidence in.
Is using the sheet metal as structure in the calcs a useful road to try?
If so, are there any good resources on calculating structural properties of formed sheet metal?
Actual issue:
