myname_earl
Chemical
- Aug 31, 2022
- 51
Currently, we are evaluating a historic system in the plant due to changes in degradation rates and evidence we're seeing.
Knowledge as of today:
1. Our coolant is 74% Water, 20% Methanol, and 6% Ethylene Glycol.
2. The system is made of A53 Gr. B and A106 Gr. B carbon steel piping.
3. Maintenance has been noticing metallic scaling/flaking being picked up in strainers and exchangers when opened. (When I saw it, it was a magnetic "goop" with solids in it.)
4. Piping and Equipment are insulated, but not painted... Known CUI targets with yearly evaluation as the pipe sweats profusely.
The latest find was a dripping leak on a pipe shoe that was welded to the pipe (also has a tie point weld in that same HAZ). This has evidence of CUI but certainly looks like there is an aggressive internal-to-external mechanism in play as well.
My question is what could be causing internal damage as aggressive as CUI in this service? SCC from the Methanol? Glycol becoming acidic? I don't have samples collected yet, but will once we replace the spool.
Fixes for my potential problem(s)?
Mechanical Integrity Specialist (Year 1)
