We are considering to install Variable Speed Drives on our 2 cooling towers to save energy and money. The towers's fan is 10 HP and the pump is a Monarch Industries BSEF-750 (Specs: (7.5 HP).
Basically, the hot water arrives in a tank, enters the tower and is stored in another tank until it is needed by our machines. Presently, the pump and the tower fan are both activated at full speed when the output tank reach a predetermined low-level (to give an idea, it's activated about 5 min every 10-15 min). The output temperature varies, but since it's used to cool down molds, if it's hotter, we simply use more water. But this temperature variation requires more adjustments on the process and we would like to make it more constant.
I think we have a couple of options:
- Simply put a VSD on the fan motor to slow it down when necessary, and only activate it when the pump is working. (but this does not represent much energy and money savings)
- We put a VSD on the fan and the pump to slow both of them down. The pump only pumps the required water by our process (controlled by the tank level) and the fan regulate the output temperature.
I wanted to estimate the savings of that last option, but I'm not sure about how to do it with the pump. I can't find any chart on the manufacturer's site that tells me how the pump whould react at a lower speed (I also called them, and they told me they can't help me...). The only chart is at full speed (see the link I gave earlier). The tower is approximately 30 feets directly above the hot water tank.
Can anyone help me with these saving estimations? And do you think I should install VSD on both the pump and the fan or is it a waste of money in my case?
Thank you,
Stephane Richard
Thank you,
Stephane Richard
