Hi guys:
I was looking to find thermodynamic or aerodynamic section to put my threat in which is :
As i understand water cooling towers work on evaporation cooling principle, with the water temp drop depending on initial water temp and air initial temp and humidity or (wet bulb temp)!
now if my goal is to cool water down to as much as possible ,does any of the following seem practical:
Heating the upcoming air befor intering the tower
Reducing air humidity using baking soda or table salt or paper cellulose fiber befor intering the tower
The air in my area is at temp 23 at midday with humid about 18%,which gives me about 10 temp drop only..
Thank you.
Thank you.
