PagoMitch
- Sep 18, 2003
- 71
The accepted Cooling Tower efficiency value is defined as a function of inlet, outlet, and wet bulb temps. I can find no benchmark type of parameter that include power input for the fan.
I recently replaced a pair of small (physically) 30HP centrifugal fan towers with a pair of larger (physically) 5 HP prop type. Same system capacity, slightly increased efficiency, but an 83% reduction in power requirements. While the towers were about $100k, the savings in energy resulted in a less than 1 year payback!
I'm now trying to write some performance specs to define this process. Other than making prospective bidders perform a simple payback calculation and specify a timeframe, is there an industry accepted rating of some type that would incorporate tower efficiency AND power input?
