I have a question on choosing cooling tower or dry cooler. It is required that the cooling tower through the winter season. But it may have some freezing issues. I am thinking separate the sump and locate it indoor and put the cooling tower at the highest point of the building. So, when the cooling tower is operating in winter, the water will fall back to sump by gravity and the sump is kept above freezing point all time. The cooling tower fans can run reversely to defrost the ice outside the pipes.
Could someone having more experience with cooling tower give me some suggestions on this? Thank you so much!
