1. what is the most suitable method in switchgear manufacturing either using already tin plated busbars or get tinplated after cutting and drilling before assemble?
2.If manufacture uses tinplated bus bars how can they treat drilled holes and cutting ages which got exposed ? are there any approved Sn based paints available ?
3. Are there any International standard for tinplating of copper bus bars where required testing methods are specified to assess the quality of tinplating ?
4. Are there any methods available to use in the site /field to repair /touchups discolored / pealed off areas in tinplated busbars mounted inside a panels.
Thank you
BR
Rukshika
Thank you
BR
Rukshika
