Copy & Paste published elements in context 2
mrawlinc
Industrial
SI
I have one level assembly with multiple parts and their instances on different positions. Parts already have published elements (lines and axis systems) that are needed to be copied in (empty) part called "Positions" which is in the in same assembly, so the position of copied elements doesn't change, and also their name should be same as in source part.
I have very very basic skills on programming, so I searched for a similar macro, but couldn't find it ... does anyone have something similar that I could use for a start?
newpart is a product type, you cannot paste geometry on a product part, you need to have the paste target inside newpart.
newPart is the instance (Product)
newPart.ReferenceProduct is the reference product of the instance (Product)
newPart.ReferenceProduct.Parent is the document supporting the reference product (PartDocument)
newPart.ReferenceProduct.Parent.Part is the part of the document (Part)
inside this part you can create a geometricalSet if you want:
Code:
Dim targetpart As Part
Set targetpart = newPart.ReferenceProduct.Parent.Part
Dim geomSetTarget As HybridBody
Set geomSetTarget = targetpart.HybridBodies.Add
geomSetTarget.Name = "Scripted External Reference"
Eric N.
So here is code, which copies all published elements from visible parts and their instances in assembly, creates new part, in this case called "Positions", and pastes elements in it. For now it works only with one level assembly.
Special thanks to itsmyjob for guidance&help!
Code:
Sub CATMain()
    Dim rootProduct As Product
    Set rootProduct = CATIA.ActiveDocument.Product
    If InStr(CATIA.ActiveDocument.Name, ".CATProduct") < 1 Then     'product/part check
        MsgBox rootProduct.Name & " Is NOT Assembly!"
    Exit Sub
    End If
    'Debug.Print rootProduct.Name & " Is Product!"
    Dim PartsCount As Integer
    PartsCount = rootProduct.Products.Count     'count of parts and instances to use
    Dim newPart As Product
    Set newPart = rootProduct.Products.AddNewComponent("Part", "Positions") 'create part paste in it
    Dim targetPart As Part
    Set targetPart = newPart.ReferenceProduct.Parent.Part
    Set geomSetTarget = targetPart.HybridBodies.Add
    geomSetTarget.Name = "CopyOfReferences"
    Dim vp As VisPropertySet
    For i = 1 To PartsCount
        Set instance = rootProduct.Products.Item(i)
        If isVisible(instance) Then                         'hide/show check to copy only visible parts
            Dim publCount As Integer
            publCount = rootProduct.Products.Item(i).Publications.Count
            Dim selectedEL As Selection
            Set selectedEL = CATIA.ActiveDocument.Selection
            selectedEL.Clear
            For j = 1 To publCount
                Set publishedEL = rootProduct.Products.Item(i).Publications.Item(j)
                selectedEL.Add publishedEL
                'Debug.Print (rootProduct.Products.Item(i).Publications.Item(j).Name & " published element is added to selection")
                'Debug.Print newPart.Name
                selectedEL.Copy
                selectedEL.Clear
                selectedEL.Add targetPart
                'selectedEL.PasteSpecial ("CATPrtResultWithOutLink")            'paste as result WITHOUT link
                selectedEL.PasteSpecial ("CATPrtResult")                        'paste as result WITH link
                selectedEL.Clear
            Next
        Else
            'Debug.Print (instance.Name & " is NOT visible")
        End If
    Next
    newPart.Update
End Sub
Function isVisible(ByRef object As Variant) As Boolean      'function for cecking hide/show of part
    CATIA.ActiveDocument.Selection.Clear
    CATIA.ActiveDocument.Selection.Add object
    Dim showstate As CatVisPropertyStatus
    Set vp = CATIA.ActiveDocument.Selection.VisProperties
    vp.GetShow showstate
    result = True
    If showstate = catVisPropertyNoShowAttr Then result = False
    isVisible = result
End Function
[thumbsup2]
Eric N.
Now I can share this valuable [link ]link[/url].
But I'm glad you stayed here with me and learned & share your result.
Just few more things:
you did comment your code, but not enough... please give more info while commenting. Check CATScript in v5automation.chm
if you want to work with multi level product you need to learn about Recursion.
Eric N.
I'm expanding this macro to retrieve some numbers (position, angle,...) from elements which are copied As result with link, so planes and lines are automatically pasted in External References. Now I'm trying to access them trough HybridBodies, but cant figure out under which collection are they ...
Here is my code:
Code:
Sub CATMain()
    'first check if document is part or product
    Exit Sub
    End If
    'Enter name od new Part
    Dim newPartName As String
    newPartName = InputBox("Please enter new Part name.")
    Set newPart = rootProduct.Products.AddNewComponent("Part", newPartName) 'create part paste in it
    'create Geometical set in new part
    'Dim geomSetTarget As HybridBody
    'Set geomSetTarget = targetPart.HybridBodies.Add
    'geomSetTarget.Name = "CopyOfReferences"
    'loop trough parts
        'check if part is visible, so it takes only visible parts
            'count published elements which will be copied
            selectedEL.Clear
            'loop trough published elements in every part
                selectedEL.Copy
                selectedEL.Clear
                'uncomment if paste WITHOUT link
                'paste elements WITH link
                selectedEL.Clear
            Next
        Else
        End If
    Next
    newPart.Update
'Section for retreiving positions and rotation angle fo elements
    Dim axisCount As Integer
    Dim LinesCount As Integer
    Dim Xaxis1 As Double
    Dim Xaxis2 As Double
    LinesCount = targetPart.HybridBodies.HybridBody.Item(1).GeometricElements.Count
    Debug.Print LinesCount
    'counting axissystems in new part
    axisCount = targetPart.AxisSystems.Count
        'Loop trough axissystems to retreive components
        For i = 1 To axisCount
            Set ASys = targetPart.AxisSystems.Item(i)
            Set Oref = targetPart.CreateReferenceFromObject(ASys)
            Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
            Set TheMeasurable = TheSPAWorkbench.GetMeasurable(Oref)
            Dim Components(11)
            TheMeasurable.GetAxisSystem Components
            Components(0) = Round(Components(0), 3)
            Components(1) = Round(Components(1), 3)
            Components(2) = Round(Components(2), 3)
            Components(3) = Round(Components(3), 4)
            Components(6) = Round(Components(6), 4)
        Debug.Print targetPart.AxisSystems.Item(i).Name & " x "; Components(0) & " y "; Components(1) & " z"; Components(2)
        Xaxis1 = Components(3)
        Xaxis2 = Components(6)
            If (Xaxis1 = 1) And (Xaxis2 = 0) Then           'Parallel to X
                Debug.Print "Parallel to X"
            ElseIf (Xaxis1 = -1) And (Xaxis2 = 0) Then      'Parallel to X 180° rotated
                Debug.Print "Parallel to X 180° rotated"
            ElseIf (Xaxis1 = 0) And (Xaxis2 = -1) Then      '+90° rotarted
                Debug.Print "+90° rotarted"
            ElseIf (Xaxis1 = 0) And (Xaxis2 = 1) Then       '-90° rotarted
                Debug.Print "-90° rotarted"
            ElseIf (Xaxis1 > 0) And (Xaxis2 < 0) Then       'First quadrant
                Debug.Print "First quadrant"
            ElseIf (Xaxis1 < 0) And (Xaxis2 < 0) Then       'Second quadrant
                Debug.Print "Second quadrant"
            ElseIf (Xaxis1 < 0) And (Xaxis2 > 0) Then       'Third quadrant
                Debug.Print "Third quadrant"
            ElseIf (Xaxis1 > 0) And (Xaxis2 > 0) Then       'Fourth quadrant
                Debug.Print "Fourth quadrant"
            End If
        Next
End Sub
    result = True
    isVisible = result
End Function
