Copy Partbody from product Instance
peterbeamish1
Automotive
Aug 16, 2013
13
I need to copy a partbody from an instance of a product to another product. How might I go about this?
Copying:"Removal : male"
to
"55227-8#K813 Male Plate.CATPart"
syntax may not be perfect, looking for code on how to access specific instances. copying from the document as a whole seems to give an error.
What do you recommend?
THANK YOU VERY MUCH IN ADVANCE!
Peter
CODE:
for i=1 to cavNumb
cavdesign = "55227 Cavity Design." + i
Set product3 = products2.Item(cavdesign) 'loop this
Set products3 = product3.Products
Set product4 = products3.Item("55227 Male Cavity.1")
'ERROR IS IN HERE I THINK
set product4 = product4.parts
set myPart = product4.part
set DerBODIES = myPart.Bodies
' ^i have no idea how to access an instance of a product
Set theBody = theBodies.Item("Removal : male")
selection1.add theBody
Set partDocument2 = documents1.Item("55227-8#K813 Male Plate.CATPart")
Set part2 = partDocument2.Part
selection2.Add part2
selection2.Paste
next
As I understood, you have a product with few catparts and you want to copy bodies from a specific catpart to another one (inside same loaded product)?
Then you need to make first active the target part (blue highlight, using Part Workbench) and then use Paste (with or without link ? ).
If I remember correctly there is somehow a similar post here in forum.
Fernando
Just to clarify, I have many instances of a single product. I need to copy a body WITH link to another product where they will be future accessed. There are upwards of 60 children (instances) of the product within the product as a whole.
EX.
552278 Cavity Design(552278 Cavity Design.1)
552278 Cavity Design(552278 Cavity Design.2)
552278 Cavity Design(552278 Cavity Design.3)
Need to access each of ^ these and copy out a partbody they hold WITH link.
Peter
I got this far, How can i access and a partbody from oProd?
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set documents1 = CATIA.Documents
Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart")
'---- Begin resolution script for object : 55227 Cavity Design.1
Set product1 = productDocument1.Product
Set products1 = product1.Products
Set product2 = products1.Item("Cavity Group.3")
Set products2 = product2.Products
Set product3 = products2.Item("55227 Cavity Design.1")
'---- End resolution script
search(product2)
end sub
Sub Search(oProduct)
Dim Prod1
For i = 1 To oProduct.Products.Count
Set Prod1 = oProduct.Products.Item(i)
'Rename here
If Prod1.Products.Count <> 0 Then
copy(prod1)
End If
Next
End Sub
sub copy(oProd)
'msgbox oProd.name
Set bodies1 = oProd.Bodies
Set body1 = bodies1.Item("Removal : male")
body1.copy
'dfffff.PasteLink
End Sub
You are using recording function as I can see, your macro is very posible not to work for other products or parts or if someone is doing a small change in the part which now have (for example) Cavity Group.3
So called "Hard code" is not the best idea (I must admit I'm using also but just for quick-dirty macros as someone said...).
Is dificult to recreate and test your scenario without some sample files (and again, I believe no one is loosing time to recreate a Product structure).
Fernando
The changes are not happening in cavity group. I need to copy from cavity group.
In response, this macro is necessary because otherwise I would need to copy and paste manually upwards of 60times (before doing other steps). Please examine this code:
It is working up until the copy paste section:
Language="VBSCRIPT"
Sub CATMain()
search(product2)
end sub
Dim Prod1
'Rename here
copy(prod1)
End If
Next
End Sub
sub copy(oProd)
dim sel
'msgbox oProd.name
'NEED CODE HERE
Set products3 = oProd.Products
Set myObject = products3.Item("55227 Male Cavity.1")
Set HEREISIT= myObject.ReferenceProduct
set prodDoc = HEREISIT.parent
Set thepart1 = prodDoc.Part
Set bodies1 = thepart1.Bodies
'get solids here
Set sel = prodDoc.Selection
sel.add body1
'sel.copy
CATIA.ActiveDocument.Selection.Copy()
dim selection2
Set documents11 = CATIA.Documents
Set partDocument22 = documents11.Item("55227-8#K813 Male Plate.CATPart")
Set part22 = partDocument22.Part
set selection2 = partDocument22.selection
selection2.Add part22
'selection2.PasteLink
'selection2.Paste
'THIS GIVES AN ERROR
CATIA.ActiveDocument.Selection.PasteLink()
'part11.PasteLink
End Sub
Thank you for your replies
I am attaching a sample file of our companies file structure. This document should be used as an example, only to better understand what needs to be accomplished.
The macro should take:
-Cavity Group (Cavity Group.3)
----SAMPLE Cavity Design(55227 Cavity Design.X) <-This product will be cycled in a for loop.
---------55227 Male Cavity (55227 Male Cavity.1)
---------------Removal : male
COPY TO:
-SAMPLE Male Plate(Male1)
At the end, SAMPLE Male Plate Should Contain many "Removal : Male" bodys
Thank you
 http://files.engineering.com/getfile.aspx?folder=c9677082-b029-4c4d-b8f5-126980582157&file=SAMPLE.rar
Hi
One solution could be like in code below in CATScript, is done just for one body, you need to adapt the code for the others....or find another solution, for example to copy all bodies in one shot.
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim productDocument1 As Document
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Clear
''''''''''''''get the part from where you copy the body
Dim documents1 As Documents
Dim partDocument1 As Document
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
selection1.Add body1
selection1.Copy  '''' copy Removal : male
''''''''''''''activate the target part
Dim selection2 As Selection
Set selection2 = productDocument1.Selection
selection2.Search "Name='SAMPLE Male Plate',all"   ''''''select by searching the name
        Set partDocument1 = documents1.Item("55227-8#K813 Male Plate.CATPart")
        Dim editPart
        Set editPart = partDocument1
        CATIA.StartWorkbench("PrtCfg")
        editPart.Activate()'    '''''make the part active (highlight - blue color)
	selection1.PasteSpecial "CATPrtResult"  ' ----- Perform Paste As Result With Link
End Sub
Fernando
Thanks again fernado,
I don't think my main problem is being communicated correctly. I have working copy and paste code, but what I don't understand is how to copy specific items (I.e SAMPLE Cavity Design 55227 Cavity Design.X) and NOT the document itself. My "Search" subroutine loops through each product I need and calls the copy routine with the correct part. Inside sub copy how do I select and copy prod (and NOT partDocument1)?
NOTE: Different names are used in this code (not SAMPLE) but the tree structure is identical.
Code:
Language="VBSCRIPT"
Sub CATMain()
search(product2)
end sub
Sub Search(oProduct) 'THIS SUB RETURN EACH PRODUCT
    Dim Prod1
            'Rename here
			copy(prod1)
			msgbox prod1.name
            End If
        Next
End Sub
sub copy(oProd)
Dim documents1
Dim partDocument1
Dim part1
Dim bodies1
Dim body1
Dim selection1
selection1.Copy
paste
end sub
sub paste
Dim selection2
'selection2.Search "Name='SAMPLE Male Plate',all"   ''''''select by searching the name
selection2.Search "Name='55227-8#K813 Male Plate',all"   ''''''select by searching the name
        Dim editPart
        'CATIA.StartWorkbench("PrtCfg")
        editPart.Activate()
'	selection1.PasteSpecial "CATPrtResult"  ' ----- Perform Paste As Result With Link
'CATIA.ActiveDocument.Selection.PasteLink()
End Sub
Peter
You cannot copy a CATProduct in a CATPart. What I understood you want to copy some bodies from a CATPart inside another one, no matter where they are in CATProduct, this is what you can do.
Hope you understood the hierarcy in a Product structure. You can copy what ever you want by making the parts active (blue highlight) and make the target active and paste there (and this can be done under CATProduct or in separate windows...).
Fernando
Okay this makes more sense.
So within the sub search, activate the specific part before trying to copy from it?
Code:
    Dim Prod1
            'Rename here
'ACTIVATE CODE HERE	<-------------------------------------------------------------------
copy(prod1)
			'msgbox prod1.name
            End If
        Next
End Sub
What should i be activating? The product or the part? If part, how to I select that specific one?
thanks
Just do some operations manually and record a macro, see what is recording and try to correlate with what you've done.
So, if you want to copy something from a Part, of course you need to get it...remember? ......Item("55227 Male Cavity.CATPart"). You can get it also by Instance Name...
Read a little bit more carefully the macro posted and try also to read about this in v5automation.chm file...you have a lot of things to learn when you start to do something like this.
Fernando
Thank you for your post
I understand the basics of copy from a part. This particular case required you to copy from a instance of a part within an instance of a product. I understand the product structure, but am hung up on selecting a body within two instances. Here is the section of code that needs work:
Code:
    Dim Prod1
            'Rename here
			copy(prod1)
			'msgbox prod1.name
'prod1.activate()
            End If
        Next
End Sub
sub copy(oProd)
'Dim productDocument1
'Set productDocument1 = CATIA.ActiveDocument
set trythis = oProd.products
'Dim documents1
'Set documents1 = CATIA.Documents
'Dim partDocument1
'Set partDocument1 = documents1.Item("55227 Male Cavity.CATPart")
Dim selection1
Set oDoc = CATIA.ActiveDocument
Set oProd1 = oDoc.Product
Set oProds1 = oProd1.Products
set oProds11 = oProds1.item("Cavity Group.3")
Set oMyDoc = oProds11.products
set newT = oMyDoc.item(oProd.name)
'set newnewT = newT.products
'set bbodies1 = newT.Bodies
set newnewT = newT.ReferenceProduct
NumberOfItems = newnewT.Products.Count
Dim bodies1
Dim body1
For k = 1 To NumberOfItems
Set maybe = newnewT.Products.Item(k)
'msgbox maybe.name
if  maybe.name = "55227 Male Cavity.1" then
		set secndRef = maybe.referenceProduct
		secndRef.activate()	'error here, the following lines of code have errors as well. How do i select the particular_ 'instance?
	set part1 =secndRef.part
end if
next
selection1.Copy
paste
end sub
