Copy Wizard Settings
Joeseph55
15
Hello All
Thank you in advance.
After win10 current update my "copy setting wizard" not working in the Solidworks Resources tab (right side) as well as other functions in the Solidworks tools area. Any ideas?
Here's what I did thus far.
1. I did a thorough cleaning of Solidworks in the files, folders & register.
2. I reinstalled SW2014 3 times already using different installation add-ons.
I also noticed I cannot access, the following on the same dialog box (Solidworks Tools, on right side of screen in Red Boxes and Tip of the Day)
In addition, I cannot use this function through the SW file/folders.
Best Regards
KenJG
 https://files.engineering.com/getfile.aspx?folder=f94becd2-34df-4e60-b737-1250b2891caa&file=Solidworks_Resources_Tab_Issues.jpg
SW2014 is not supported on Windows 10. Windows 10 support started with 2015sp5. See
Solution: Try accessing these items through the Start menu rather than the Resources tab. I'm pretty sure all these items are available in the "SolidWorks Tools" folder of the Start menu under a default install.
Thank you for the feedback.
I cannot access this thru the Start Menu either. It worked before I updated windows recently. I seems like the area is being blocked somehow. Not sure what's going on. It works fine on my home computer with Win10 Home.
Best Regards
KenJG
