Copying a view from one sheet to another sheet of the same file (without scripting) 2
CAD2015
Computer
Jan 21, 2006
2,025
Is there any way to copy a view from one sheet to another sheet of the same file, other than using scripts?
I tried to cut/copy and paste but it doesn't work:
Thanks......
CAD 2015
I've just found one way:
1) Copy the initial sheet
2) Past that sheet and retain only the view you want.
Does anybody know a better option?
CAD 2015
Thanks Ferdo for prompt reply.
All the views were created in "Working Views".................
I am using the "trick" that I mentioned; it works just fine.
I am always looking for multiple option related to a CAD procedure......
Thanks a again!
CAD 2015
I see...…
It doesn't work in my case: I can't copy and paste a view from one sheet to another.
I believe that the Catia that has been provided to work on, has some issues.
In one of my previous threads I asked for same directions for a 2D table updates...….
I'll comeback here after I'll make a full list of my Catia license shortcomings....
Thanks for your time!
CAD 2015
Select the sheet you want to copy to in the tree first, then paste. The paste function goes to the currently selected item.
