yeagsman85
I have an assembly (1234 - Assembly A) with a drawing that I have set up in Teamcenter as a specification. I have another version of the same assembly (5678 - Assembly B) that I need to create a similar drawing for. Is there any way to take the drawing for Assembly A, copy it, and attach it to Assembly B?
I've tried to use 'Save As' but there doesn't seem to be a way to save it as a specification tied to another part. It will only allow me to save it as a stand alone part. I've also tried to export it and then import it but there are over 30 parts in each assembly and some of them are different so I'm not real sure if that's what I want to do.
The only two options that I can come up with are to save Assembly A and the drawing as Assembly B and then replace the parts that I need to change to recreate Assembly B as it stands now. The other option would be to create the drawing for Assembly B from scratch but that would be a hassle because I also have Assemblies C through J that I have do this for as well. Any suggestions?
