Hi guys,
I have a situation where an existing 600 x 190 beam (24" x 8") needs to be cored so services can pass through. My thoughts are that I should try to do this in a low shear region because the beam is not going to be scanned to determine the location of the shear ligs.
And I should core approximatley within the middle third of the depth, this way I will avoid any tensile steel and the compressive stress block should not be affected depending on the depth of the neutral axis.
What do others think of this logic.
